Re: Question about F12 fuel tank
Posted by arkfisher on August 03, 2013 at 10:11:51 from (24.40.234.61):
In Reply to: Question about F12 fuel tank posted by arkfisher on August 02, 2013 at 15:31:55:
Ok guys... a little baffled here (no pun intended)
I've looked down in the tank with a good light and I see no holes in the baffles that will let fuel flow through to the outside sections of the tank. I put half a gallon of gas in and set it up on the side to let it drain through, but very little to none went through.
I wish I could get a camera in there to show you all what I'm looking at.
However, I can still hear the gunk rattling in there... On the bright side, it looks like I don't have any rust in the center section, just black varnish chunks.
I'm going to take it to the neighbors and use his steam cleaner on it then go with some acetone. I was really looking forward to the ball bearing idea, but there are no holes!
Thanks again guys,
Richard
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
