Posted by 36F30 on August 03, 2013 at 13:38:21 from (174.30.66.131):
In Reply to: F-20 backfire posted by EM Iowa on August 03, 2013 at 12:11:54:
Nothing odd about it at all, you are right on the edge. Meaning you are firing just slightly before top dead center. There is a lot of iron your spinning there and usually its momentum overrides the early fire, but on the kickback occasions the momentum was not enough to overcome the early spark. Listen to Cowman and Reset your timing before you experience a full fledged kickback that breaks something or launches the crank. Its a he!! of an eye opener when they bounce around the shop or your arm hurts for a couple weeks
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
