F30 belt pulley leak
Posted by koehleraj67 on August 03, 2013 at 15:31:45 from (65.103.22.145):
Hello,
I have an F30 that I finally got started and noticed that there is a leak coming out of the end of the pulley (not the portion that connects to the tractor but and the end of the shaft that connects the pulley to the shaft. upon inspection it looks like the ends match up and where the bolts are but on the sides all the way around it looks like there is a gap that goes from flush to an 1/8 of in inch then back to flush between bolts. is this normal or is in wrong all together? what can I do to stop the leak but still be able to use the pulley? is there a special gasket that is missing?
