Re: c-135 in a farmall c
Posted by Erik Dekeyser on August 03, 2013 at 17:55:43 from (184.151.61.76):
In Reply to: c-135 in a farmall c posted by dennis p on August 03, 2013 at 14:37:26:
Last winter I put a swather engine into a super C and it was a c135. It bolts right in but there are a few things I needed to change. First of all the C135 didn't have a drilled crank like the C did so I had to cut the shaft of about an inch and I got a bushing machined to fit the fly wheel so it would take a bearing. Also the rad is different on the 135 so the easiest thing to do was to get another rad from a 140 and that worked out great. If you have any questions just email me. Erik.
