Re: W-6 Hydraliic's,
Posted by Janicholson on August 03, 2013 at 19:07:49 from (74.60.94.18):
In Reply to: Re: W-6 Hydraliic's, posted by Janicholson on August 03, 2013 at 19:05:43:
The valve should have a pressure relief control set to no more than 1200 PSI with the IH distributor pump. Jim
