There are several ways to do it. One absolute is the linking of the spindles so they follow Ackerman principles. A tierod between the sides and attached to steering arms as shown in the diagram, is a good solution. If the 504 has 2 push pull drag links from a gear box, one on each side, that geometry (and the gears in the box that control the links, as well as the geometry of the arms on the box,) are responsible for the Ackerman effect. Thus if your front end has that Utility style linkage, either the gears are needed, or new fabricated steering arms on the spindles are needed with a link between them as shown in the diagram. Two different approaches are used to power the steering one type uses 2 identical single acting cylinders, each pushing in opposite directions. Sometimes they are placed on the drag links on opposite sides, sometimes attached to the center of the cross rod and anchored to the axle. Some use a single double acting cylinder that pushes and pulls on one link. Either way a bracket, or two, must be welded (with professional absolutely fail proof strength) so the cylinder/s are positioned to allow full steering movement "lock-to-Lock" Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
