Re: W-6 Hydraliic's,
Posted by Janicholson on August 04, 2013 at 06:53:54 from (74.60.94.18):
In Reply to: Re: W-6 Hydraliic's, posted by Kansas Kirk, on August 04, 2013 at 05:17:36:
third party image
The diagram shows multiple double acting valves. it is the same if only one valve is used. A single acting valve is also shown it also can be used alone. The key is the connection through all valving back to the reservoir. Jim
