Re: F-20 Runs Rough
Posted by EM Iowa on August 04, 2013 at 18:24:09 from (67.55.190.168):
In Reply to: Re: F-20 Runs Rough posted by clint s on August 04, 2013 at 15:27:44:
Check to see if you have a steady stream of fuel going to your carb (use the drain feature on the carb), and if you do have a steady stream then it may be a distributor problem. Has the valve lash been set?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
