Re: positive ground on a H
Posted by Janicholson on August 04, 2013 at 20:18:15 from (74.60.94.18):
In Reply to: positive ground on a H posted by INBrett on August 04, 2013 at 18:18:00:
To polarize the generator (when you put the cables as they are on the SC, and which is the way it came from the factory), With the engine off, (do not start it before polarizing)take a piece of copper wire #12 or 10 gauge, and jump from the Bat terminal on the cutout relay to the Arm terminal on the relay. This magnetizes the iron in the poles so it charges correctly. No other effort is needed.
I have attached John T charging analysis to help if it still does not charge. And diagrams from Bob M if wiring is needed. Jim
