Re: W-6 Hydraliic's,
Posted by mkirsch on August 05, 2013 at 06:19:50 from (64.80.110.74):
In Reply to: W-6 Hydraliic's, posted by Kansas Kirk, on August 03, 2013 at 18:27:07:
W-6 did not have a hydraulic system from the factory, so whatever this is, is pieced together.
So no, it won't have a pressure relief valve unless the person who set it up installed it.
It should be pretty simple.
1. From the pump's pressure output, you connect to the IN port on the OPEN CENTER valve.
2. From the valve's OUT port, you connect to a port near the top of the hydraulic reservoir.
3. From the bottom of the hydraulic reservoir, you connect to the pump's suction input.
With an OPEN CENTER valve, this system will just circulate the fluid until someone pulls the lever.
The OPEN CENTER valve you use should have a pressure relief valve built in to prevent blowing out the seals in the pump. However, it needs to be set properly or else it's as good as no relief valve at all. From the factory they come set for modern high-pressure hydraulic systems. Read the manual that comes with the valve to learn how to set the pressure relief.
A separate pressure relief valve can be installed in between the pump's pressure output and the IN port on the valve as well. The outlet from this valve gets connected to the reservoir.
