Re: Magneto impulse lag angle
Posted by Owen Aaland on August 05, 2013 at 06:52:19 from (216.47.33.157):
In Reply to: Magneto impulse lag angle posted by Nebraska Cowman on August 05, 2013 at 05:46:00:
You've got the right idea Nebraska Cowman.
A magneto fires when the points open. When properly timed this happens at 23° BTDC. With the retard mechanism engaged the magneto stops turning while the engine continues to turn. In the case of the IH magneto the engine turns 23° before the dogs in the retard mechanism are released. This causes the spark to occur at TDC rather than 23° BTDC.
The spark control is just backwards from most battery ignition distributor system. The magneto has a mechanism to retard the spark while distributors use a mechanism to advance the spark.
