Re: Magneto impulse lag angle
Posted by John T on August 05, 2013 at 08:31:47 from (216.249.76.176):
In Reply to: Re: Magneto impulse lag angle posted by Bob M on August 05, 2013 at 07:40:14:
Thanks old friend, I dont recall seeing any lag angle adjustments when I look at the IHC mags torn down on an assembly board like Grant has at the Florida Flywheelers. Still, if you rotate the mag in its flange that changes BOTH timings so I see how a fixed lag angle can still work to set the start at TDC. The Wico C and X etc were mdae to be used on a ton of different tractors and can work in either direction so they needed to be able to adjust the lag angle.
John T
