I noticed the "advance a little" comment too, and drew the same conclusion. From the video, you really couldn't see how he was gripping the crank. It thought maybe his thumb was on the wrong side for the second pull. I've caught myself gripping properly for one pull then not doing it right if I need to do a second.
Here is a video I did a while back. At about 1:30 I explain the grip.
There is very little risk in hand cranking if the engine is set properly and the cranking is done properly. I won't hand crank an engine that somebody has set the timing "by ear".
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
