Assuming it is a 10SI alternator or Hitachi, Wired as a three wire setup, not a one wire setup. A 10 ohm resitor, a side marker light bulb, or a 3amp diode with the band end toward the alternator will fix it. It is in series with the wire going to the #1 small terminal on the alternator, connected to the ignition switch, or coil wire going to the ignition switch (possibly hooked to a ballast resistor at the coil). Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
