Posted by Ramon in Krakow on August 05, 2013 at 21:15:29 from (64.103.25.103):
Greetings folks I just wanted to thank everyone again for the advice on getting the tractor running again as indeed she is now. Based on the advice provided, I created a checklist and methodically went down each in terms of perceived complexity. The very last task, which I was avoiding, was changing the points due to some inexplicable fear that it was beyond my capabilities. I changed them out and when I started the engine, it ran beautifly for a minute, then died again. For a few weeks, I kept at it trying to troubleshoot but at last, with a certain amount of resignation, I went to my neighbor (who is a mechanic) and asked him if he could assist in fixing this problem that turned out to be more than I could handle. He then said that he also wanted to bring in another mechanic friend from down the road (mind you, they don"t speak English and my Polish is pretty poor so this took quite a while to convey). So as I was walking them through the process of how the tractor operates, as they realy only have diesel tractors in Poland (mostly Ursus brand), I noticed that the gas in the sediment bowl was clearly too low, no doubt after I emptied the tank and added fresh gas. After adding some gas, I turned the tractor over and most amazingly, the tractor not only started running, but the best it has run in 5 years. So in fact, I had indeed fixed the problem but at the cost of looking a bit the fool in front of two mechanics who probably chalked up it up crazy Americans ;-) I wanted to confirm the tractor would run under load, so I ran it for over an hour bush-hogging our pasture and it pulled with no problems all over our hilly land, so it is clearly good to go and running smooth. So thanks again to everyone on the board, hugely appreciate the support! Ramon
PS. Of course, as I was going hog wild bush-hogging, I appear to have damaged the seed plate drive oil seal but I will save that for a separate post.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
