When I first got my "B" it would take 4 pulls of the crank to start it after I killed it when trying to drive it around and learn its gearing. The first two nothing, the third it would kickback, and the forth usually it would start.
I solved that by properly setting the timing per the manual, that is to set them at the "Fire" mark on the flywheel (30degrees BTDC) and spin the mags backwards (no impulse) until the mark under the cap (FMJ mag) is lined up and then put them in and fine tune them to that mark. Sounds like the Allis' you tried cranking were set a bit too advanced.
Still haven't gotten either of my internationals (Regular and W30) rebuilt yet so the verdict is still out on how much trouble they will be for me.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
