Re: 6 Volt Battery Wont Turn Cub??
Posted by old on August 06, 2013 at 09:25:39 from (209.86.226.32):
In Reply to: Re: 6 Volt Battery Wont Turn Cub?? posted by anvilheadtexas on August 06, 2013 at 09:23:14:
Well unless your jumper cables are say 0 or 00 in size they are way way to small to carry the amps needed to spin a starter on 6 volts. 6 volt systems draw high amps at low volts so yep you need bigger battery cables not the jumper cables
