Re: Miss fireing H
Posted by old on August 06, 2013 at 09:55:20 from (209.86.226.11):
In Reply to: Miss fireing H posted by Alvin Dick on August 06, 2013 at 08:34:18:
That can be many things. Valves not set right or a bad rotor and or cap or bad distributor bushings etc etc. Check your spark at all 4 plug wires and make sure it is a good blue white and will jump a 1/4 inch gap or more. Also check that the points open to the same gap on all four lobes of the distributor
