Re: 6 Volt Battery Wont Turn Cub??
Posted by mkirsch on August 06, 2013 at 10:23:36 from (64.80.110.75):
In Reply to: 6 Volt Battery Wont Turn Cub?? posted by anvilheadtexas on August 06, 2013 at 08:21:47:
Even if you have super-heavy jumper cables, the clamps only have a small area of contact, just the tips of the teeth.
Usually the biggest problem is finding a good ground. Clamping on to rusty metal is usually the main cause.
Odds are the starter could probably stand to have the commutator cleaned up, new brushes, etc. regardless.
If you want to just see if you have spark, then just use the 12V for now. It won't hurt a thing to run 12V for a few minutes.
Or, hook the coil up to 6V and the starter to 12V. Just make sure to connect the same post from each battery (both +) to the tractor frame.
