Charge the 6 volt battery overnight and then use a hydrometer to check the specific gravity of each cell. Then post the readings. Should see readings around 1.275. If one cell reads 1.100 you have a dead cell and you need a new battery. Hal PS: You need 00 cables as been suggested. Clean all connections until shiny and that includes where your battery is grounded. Don't make them any longer than necessary.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
