I would get the implement you plan to use and see if it makes the front end too light. If it does just add enough weights till the front end stays on the ground but it is not too hard to steer and that way you will not need power steering. Power steering is needed for loader work or anything that loads the front end excessively, but what you are describing should be the opposite problem. Zach
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
