All you need is a piece of steel 1/2 inch thick, 6 inches tall, and wide enough to get from one side to the other. I can't remember how far apart the holes are drilled. When I built one for my SM I used two pieces of 1/4 inch plate welded together. Then ran some 2X2 heavy square tubing back and bolted it to the frame rails. Didn't look the greatest, but I built it in metal shop in 9th grade.
You won't need power steering. It may be harder to turn once you unhook the cultivator, but then you just go pull the weights off.
Oh, and the farther in front of the tractor you put the weights, the more effective they will be. To get around the rod for the hand crank, all you need to do is slide the front plate forward til it clears.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
