Re: What would this plow be worth?
Posted by pistons on August 07, 2013 at 08:10:05 from (67.52.234.226):
In Reply to: What would this plow be worth? posted by Yooper Farmall on August 07, 2013 at 06:58:02:
It is missing coulters, has no tail wheel and has mechanical lift on axle making it a trip plow. At auctions I hear people gripe that plows should not sell for more than $100 per bottom. But in this case I would offer much less. I purchased a 2X14 Moline, tail wheel and coulters with a mechanical axle lift for $5. The lift was out of alignment so had to give that some attentions, but got the plow because the frame was so dang thick.. Trailer plows are tricky in my opinion to get set right. Getting the draft line set up correct to your drawbar and vertical height adjuster on the plow frame. The two levers are for setting depth, and for setting forward angle when cutting a new headland. Make sure they work good.
