Posted by gene bender on August 07, 2013 at 09:33:24 from (67.55.226.10):
In Reply to: Super A rear main seal posted by Adrian Billheimer on August 07, 2013 at 08:35:54:
NO that seal is quite a piece of work. The flywheel will have to be removed then the seal thingy is bolted to the block and its in two pieces and uses felt for a seal they are two small pieces and are inserted into those two halves then bolted back up to the block. The felt has to be installed very careful. The small gaskets probably can only be purchased with an out of frame gasket set. If you are careful they could be used again with some thin sealer. Only time ive replaced is when i have had the crank reground but that is the procedure.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
