Re: 1959 Farmall 560 PTO Slips
Posted by ejr-IA on August 07, 2013 at 11:57:05 from (204.11.182.17):
In Reply to: 1959 Farmall 560 PTO Slips posted by CTPhil on August 07, 2013 at 10:39:21:
You have the early model pto with the clutch bands which can be adjusted by the two screws and lock nuts on top right.One does the ingaugement and the other is the brake.The two plugs on left side one full, bottom add.Fill with new Hytran oil.When you turn the adjustments clockwise that tightens clutch bands if not its worn out.Mine where burn out took it to a good brake reline shop.
