Re: What would this plow be worth?
Posted by LA in WI on August 07, 2013 at 15:26:44 from (64.251.223.202):
In Reply to: What would this plow be worth? posted by Yooper Farmall on August 07, 2013 at 06:58:02:
Without coulters that plow will work but leave the furrow real "dirty". If you buy it you can look for coulters and brackets so you can do a better job of plowing, and those are available if you keep looking.
Those trailer plows are very easy to set up; if you buy it and need help in aligning it, I will be happy to help you.
If the hitch mechanism does not work spray it with a good oil penetrator and keep trying to make the parts move...it should come loose and be a good hitch.
The plow has possibilities.
LA in WI
