Re: Power Steering hook up on 350 IH
Posted by pete 23 on August 07, 2013 at 19:40:00 from (74.47.41.165):
In Reply to: Power Steering hook up on 350 IH posted by Joseph Hron on August 07, 2013 at 15:50:08:
I don't know from your question if you have all the other parts that go along with the torque generator or not. You need the regulator valve assembly that contains the flow divider for steering, different first aux valve in the stack and pipe running between flow divider and first valve. Hose to steering comes out of fitting on flow divider valve and return goes into the drain on reservoir with a T so you can still drain it without taking hose off. Now for the big problem. Almost all of those old flow divider valves are worn and don't work well. I was able to get the new spool for flow divider just a few years ago but do not know if it is available now. That is usually but not always the main problem. Bore can be worn also. You could put on a separate belt driven pump though like the add on char-lynn units use.
