Re: H mid-mount sickle mower
Posted by steamship on August 08, 2013 at 13:05:13 from (199.120.189.2):
In Reply to: H mid-mount sickle mower posted by ChasK on August 08, 2013 at 05:43:48:
Not that I am an expert by any stretch, but I have learned a couple of lessons from using my sickle bar mower.
To start with, what the others say is great advice. Additionally I found it a good idea to keep the angle of attack of the rock guards/bar level with the ground or slightly tipped up. Tipped down causes trouble and drags and digs the dirt instead of riding over it.
Also, have the outer part of the bar lead (further ahead) than the inside of the bar (by the tractor tire) by 2". That'll help avoid plugging up at the outer end of the bar and also reduce strain on frame of the mower.
Another thing comes to mind is the eveness of the ground. If the ground under the grass is rough and bumpy, the rock guards can dig into the high spots and block a knife or two with a clump of dirt which turns into a plugging of grass.
Regardless take your time, don't force anything and make adjustments as necessary. Good luck!
