Re: H mid-mount sickle mower
Posted by farmallmick on August 08, 2013 at 15:54:40 from (166.137.88.40):
In Reply to: H mid-mount sickle mower posted by ChasK on August 08, 2013 at 05:43:48:
Is the mower a pitman arm or balanced head. On the pitman arm type there is a bolt to adjust the pitch of the cutter-bar, it should definitely be slightly pointed above level. If it's pointed level or down it collects too much grass & clogs. Also as previously mentioned the hold downs should be adjusted (few small taps w/ a hammer) so there is minimal vertical movement of the knife (less play as the knife moves back & forth, hence an easier/better cut). Also, make sure the knife sections & ledger plates are sharp and tight (& if not replace as needed). Make sure the guards are tight & have nice points, not blunt & are in the same plane/alignment (hold the cutter bar up by the far end & look down towards the tractor & adjust up/down w/ hammer as needed. All these little things add up!
