Re: 986 gear shift hanging
Posted by Jim Naden on August 09, 2013 at 00:12:12 from (12.74.50.0):
In Reply to: 986 gear shift hanging posted by Wayne3 on August 08, 2013 at 13:58:06:
Could you define "hanging" a little better?
Did you lubricate every moving part of the shift mechanism?
