Re: Farmall M knocking noise from water pump drive
Posted by BigTone on August 09, 2013 at 04:46:53 from (70.215.7.142):
In Reply to: Farmall M knocking noise from water pump drive posted by Schultz on August 09, 2013 at 04:33:09:
When I replaced the water pump on my M, the radiator was misaligned allowing the fan to hit the shroud and it got worse as I added more throttle. I'd check that your not rubbing on the shroud first.
