Posted by jdemaris on August 09, 2013 at 05:30:02 from (70.215.16.172):
In Reply to: Re: B275 diesel posted by MJ in the UK on August 09, 2013 at 02:07:50:
I had suspected the side-mounted fuel transfer pump at one time. But after I removed it completely and installed an electric pump - the problem was still there. From what I"ve seen, it"s normal for the four injector pump plungers to leak a little and dribble fuel inside the pump box. They just get worse with time and age. Doesn"t seem to have any effect on how the tractor starts or runs unless they get real bad.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
