AV questions
Posted by Dodgeit on August 09, 2013 at 11:43:36 from (65.199.61.227):
What is the difference between the two "AV" variations I always see?
Variation number 1
Most common and is basically an "A" with 36" rubber on the back and the longer spindles up front and 19" rubber. Narrow bodied.
Variation number 2
Basically a "B" back end, 36" rubber on the rear and extended Diamond shape front axle and 19" rubber.
Other than the differences I described what gives?
Thanks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
