Re: Cranking Oil Pressure
Posted by CNKS on August 09, 2013 at 18:03:41 from (216.144.104.128):
In Reply to: Cranking Oil Pressure posted by PaulW_NJ on August 09, 2013 at 15:33:24:
Start the engine with the valve cover off, be sure you have pressure, it may take a few seconds, then look at the rocker arms. If no oil then something is plugged. I think the oil goes up thru a hole in the middle rocker arm support.
