Re: Nylon Straps for Binding
Posted by tractor vin on August 10, 2013 at 04:30:31 from (70.233.84.10):
In Reply to: Nylon Straps for Binding posted by VA Gasman on August 09, 2013 at 04:31:56:
So I just took the time to read the dot rules,Now I need to get a degree in enginering,law ,and a few more I cant think of right now I do under stand that tractors under 10000 lbs can be tied down with straps I use 4 15000 lbs one on each corner of tractor never had a problem good luke to all
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
