Re: Farmall M with engine oil dipstick ?
Posted by D Slater on August 10, 2013 at 08:19:51 from (184.14.196.10):
In Reply to: Farmall M with engine oil dipstick ? posted by jd720 on August 10, 2013 at 08:00:34:
Could be several things. Block put in from another tractor, Power unit or crawler block, IH replacement block. Also IH and aftermarket made dipstick packages for M through early 400 blocks.
Then you can also find owner engineered dipsticks installed.
If you can find a casting number on the block above the oil filter I can probably tell you what it is.
