Re: Magnet Therapy Cont'd
Posted by Rich_WI on August 10, 2013 at 08:56:50 from (50.50.82.205):
In Reply to: Magnet Therapy Cont'd posted by big_red_man on August 10, 2013 at 07:58:31:
1) I dont know if you can buy a magnetic drain plug for your specific tractor but its simple to make your own. Ebay has every size of magnet you can imagine, usually sold in packs of 10 or more so you will have extras. Just pick a size that will work well for you, drill a shallow hole in the drain plug to fit the magnet and epoxy it in place. The magnet will pretty much hold itself to the drain plug but the epoxy makes sure.
2) A hard drive magnet might fit inside the cover but you will have to check the fit.
Dont forget about the oil level check plug, thats an easy spot to add a magnet to the plug and it should get some oil splash on it to make it worth while. The fliter housing and drain plug both require losing oil to check and clean (unless you drill a new, smaller drian plug in your large drain plug).
