Re: Spark plug adapters for 44 H
Posted by 36F30 on August 10, 2013 at 09:09:54 from (63.153.210.245):
In Reply to: Spark plug adapters for 44 H posted by farmalllh on August 10, 2013 at 07:37:04:
I have a set of adapters in my JD GP. The threads were ruined in the head to the point that the plugs had been put in with J B weld so they would seal and stop coming loose. While that fix had worked, I removed them, cleaned the threads and loctigheted a set of Ream adapters into the head. ( got the correct thread tap from a model T restoration place) Now I can change plugs quickly without an overnight wait for JB weld to set up.
The adapters came with a chart of modern plugs that have the heat range and resistor -non resistor types. While I did this to save the head, I now have a multitude of options when selecting plugs including splitfire, platinum, hotter, and colder.
