Patrick if you mean the cover with pump that bolts to the rear of the liftall reservoir. The holes are blind so if it was leaking at the top bolt the housing is cracked or its leaking between the housing and gasket to the bolt then out around it. Large bolts the 7/16 ones probably don't need over 45 or 50 foot pounds if that much and the smaller 3/8 bolts maybe 25 to 40. Don't want to give you bad news but the housing is not very thick at the 2 center top bolts and could have busted. If I remember correct the bolts on the inside are 1/2 inch bolting the pump to plate and were torqued to 85 foot lb.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
