Re: How much torque on belly pump housing bolts?
Posted by John G. Hasler on August 11, 2013 at 05:52:05 from (174.124.78.43):
In Reply to: How much torque on belly pump housing bolts? posted by Patrick HMD on August 09, 2013 at 18:30:39:
> Is 90 ft lbs overdoing it on such a non critical
> item?
Not unless the manufacturer has specified a lower torque. Undertorqued bolts come loose. However, you may not have had enough thread engaged. Omit the lockwasher. It doesn"t do anything anyway.
