Re: 300 u oil filter
Posted by Mark Robke on August 11, 2013 at 06:31:29 from (71.31.17.54):
In Reply to: 300 u oil filter posted by Danby on August 10, 2013 at 23:22:55:
I have gotten the correct filter from napa before, but have went back ih/case. (Napa closed) Napa should be able to cross the to the correct filter with Bob"s info. As far as coolant in your oil, I think your liner packing rings may be leaking. Before you drain coolant and pull the head, pull the oil pan and look up at the bottom of the liners where they protrude down thru the block and see if coolant is seeping down. If they are leaking you need an overhaul. Mark
