Re: How light did/does the 16A/B/C sickle mowers make the fro...
Posted by Wm. Ecccles - Jardine on August 12, 2013 at 08:45:34 from (192.252.170.102):
In Reply to: How light did/does the 16A/B/C sickle mowers make the fro... posted by RC Brooks on August 12, 2013 at 05:32:07:
To ad a reply to the lightness of the front end NO SUCH LUCK. I should go out and photograph the hitch my father put on the a/c21 sreries for out tractor. He had it put on in the 50s. being low on the back of the mower it tends to try to lift the back of the mower when pulling a full load standard sized hay bails or the bailer and wagon. The front is a narrow two wheel type on a BN series.
