Re: Flushing hydraulic fluid?
Posted by RPM1941 on August 12, 2013 at 09:34:26 from (173.19.112.127):
In Reply to: Re: Flushing hydraulic fluid? posted by Brent in IA on August 12, 2013 at 08:14:17:
Look at color & consistency of the oil, it may be clear or caramel color, not ok if black or creamy yellow, its contaminated with dirt/grit or water. The oil doesn't ever wear out it just gets contaminated. If its a single action system ( most are) 1 hose hookup, lower the hoist, this will leave the least amount to change but know that the tractor system may need to be checked.
