Posted by Teakettle on August 12, 2013 at 17:19:34 from (74.104.135.107):
In Reply to: 674 IH 540 Shaft posted by nshawkins on August 12, 2013 at 14:57:57:
You have to take off the hydraulic lift cover on top so that you can get at the snap ring that holds the output gear (which won't fit through the hole in the back). The 1000 rpm shaft comes right out the back after you disconnect it from the PTO clutch through the side PTO hole, but the 540 is unfortunately more complicated and needs the top removed. Probably a good idea to get a manual (at least an I&T manual if not an IH one) before digging around in there so you know what to expect.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
