Re: 986 gear shift
Posted by Dalet on August 12, 2013 at 18:42:36 from (184.94.141.146):
In Reply to: 986 gear shift posted by NY 986 on August 12, 2013 at 17:30:37:
Yup I am sure that is his issue... :roll:
If you have a cab, there could be a settling issue with the rubber mounts causing the linkage to bind. If no cab, check the linkage and make sure its lubed up and adjusted properly.
Probably not much help, but more help than the other answer.
