Posted by Janicholson on August 12, 2013 at 19:01:19 from (74.60.94.18):
In Reply to: clutch won't disengage posted by truckerlary on August 12, 2013 at 18:40:25:
With safety in mind, get it backed out and drive it around in 3rd gear with the clutch blocked down. The amount of force to brake it loose should be moderate. Use of the brakes and safe free travel area are critical. Throttle it up, so the break away force is strong. Another method is to put it in high gear (hardest to turn) leave the ignition off, and hit the starter a few times this puts pretty good force on the Clutch (blocked down), and is less intense than the other way. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
