Re: clutch won't disengage
Posted by old on August 12, 2013 at 19:12:04 from (209.86.226.40):
In Reply to: clutch won't disengage posted by truckerlary on August 12, 2013 at 18:40:25:
#1 block the clutch down and then let sit 24 hours. Then if you can take it out and rive it around in the highest gear that will be safe holding the clutch down and if you can put a load on it like a weight etc to pull. Most likely condensation has rusted the clutch plate to the flywheel
