Posted by El Toro on August 13, 2013 at 06:14:52 from (108.3.143.3):
In Reply to: Farmall A Magneto posted by cubluvn8n on August 13, 2013 at 04:41:55:
You may have a weak coil or the magnets may be weak. If you decide to pull that mag you need to make a sketch where the rotor is pointing, then don't move the engine while the mag is off. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
