Re: Which one is it 15-30 or 22-36
Posted by Old-F20 on August 13, 2013 at 08:05:52 from (71.7.101.5):
In Reply to: Which one is it 15-30 or 22-36 posted by rustred on August 12, 2013 at 22:54:38:
I know, I read that, but why repeat what you said about the water pump.
he has an engine serial so that's why I put it on there
