Posted by rustred on August 13, 2013 at 09:14:04 from (74.214.152.80):
In Reply to: Farmall A Magneto posted by cubluvn8n on August 13, 2013 at 04:41:55:
what was it doing before u worked on it? did it have spark or not? a magneto usually is trouble free, even just a simple point filing keeps them going. lots of times it the condenser that fails. magnets loosing charge is not real common, but can happen. did you make sure the gap is set correctly on the high cam lob?. I check for spark before even installing them on the tractor if have one off. also make sure the impulse is snapping or you wont have a hot spark.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
